[OSRS-PROJ] Projection Information Weather Satellite
Ray Bryan E 2Lt 1 OSS/OSW
Bryan.Ray at langley.af.mil
Wed Oct 8 06:58:47 PDT 2003
Alex,
Thanks for the information. According the NOAA, its is a GOES projection.
(Geostationary Satellite). The satellite is in geosync orbit over -75
Longitude and 0 degrees latitude. They have a fortran program they use to
map to this projection. I think I will need to do some more research on
this.
Thanks again,
Bryan
-----Original Message-----
From: Alexander Weidauer [mailto:alex.weidauer at huckfinn.de]
Sent: Wednesday, October 08, 2003 10:15 AM
To: osrs-proj at remotesensing.org
Subject: RE: [OSRS-PROJ] Projection Information Weather Satellite
Brayn,
I think that will not work with affine transforms
without having the right projection of the earh body
to the a plain sheet. Do you have a idea what they mean
with Oblique Horizon projection
it seems to be a photo where the satellite is turned
over the horizont normal. I think it could determined
if you have the trace coordinates of the satellite.
To program it it's to high for me and I have to grabb
deep into the proj library. I think you should write
Gerlad Everden. He is the creator of the library
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
