[OSRS-PROJ] Transverse Mercator revisited
Gerald I. Evenden gerald.evenden at verizon.net
Tue Oct 14 18:10:09 PDT 2003
[gie at localhost dozier]$ cat biblio.txt
Tomorrow I will truck down to my modest local library and
visit the reference desk hoping I can get a copy of references
[2] through [4] below.  This process normally take 30+ days
IF successful.  I'm from Missouri and I want some solid
proof and not allegations.
According to Dozier, the problem is quite simple as I have
summarized at the end of this email.
The following is a biblography that appears to be related to
the problem of the "global" transverse mercator projection:
[1] Dozier, Jeff, 1980, "Improved Algorithm for Calculation
of UTM and Geodetic Coordinates": NOAA Technical Report NESS 81,
19 p.
[2] Lee, L.P., 1976, "Conformal projections based on
elliptical functions":---this shows up under two publishers:
B.V. Gutsell (Canada, I believe) and Canadian Cartographer
Monograph 16, Toronto: University of Toronto.
[3] Lee, L.P., 1962, "The transverse mercator projection
of the entire spheroid": Empire Survey Review, 16, 208-217.
[4] Snyder, J.P., 1979, "Calculating Map Projections for the
Ellipsoid": The American Cartographer, Vol. 6, No. 1.
Strebe makes reference to a "Wallis" however I cannot locate
any bib reference to this name except for a reference to
a Helen Wallis and a Davis Wallis award for cartographic
excellence. (?)
Incidently, in email communications with Dozier, he claimed
Snyder coded the process of his paper into a pocket
calculator (probably a TI that Snyder loved to work on).
In Dozier's paper, reference [2] was claimed to be the source
of the base equations for the transverse mercator.  The
general expression transverse mercator projection of a
ellipsoid:
psi + i lambda = arctanh(sn w) - e arctanh(e sn w)  (1)
psi = isometic latitude
lambda = longitude (from CM)
e = eccentricity
w = u + i v
sn = one of the Jacobian functions.
The Gauss-Kruger class is defined as:
x + iy = (1-e^2)int_0^w dn^-2t dt
or
    = E(w|e^2) - e^2 (sn w cn w)/dn w     (2)
where E is the elliptic integral of the second kind and
cn and dn are additional Jacobian functions.  i is
square root of -1.  Note x is northing and y easting.
Dozier's statement of the problem is: if you can find w
from equation 1 you can compute x&y from equation 2.
For equation 1 he uses Newton-Raphson and the rest is
simple, eh?
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
