[OSRS-PROJ] UTM vs TMERC
Clifford J Mugnier cjmce at lsu.edu
Tue Oct 21 09:51:52 PDT 2003
Generally speaking that is correct IF you are only interested in staying
within the +/- 3 degrees of the central meridian.  Zone extensions can be
problemmatic, especially for surveying/geodetic transformation accuracies.
When one starts "chasing millimeters," there are more mathematical details
that need to be accounted for.  For GIS applications withing the 6-degree
belt, they are usually inconsequential.
Cliff Mugnier
LOUISIANA STATE UNIVERSITY
Omry Yadan wrote:
> So generally speaking, if I have a working implementation of TMERC, its
just
> a matter of parameters to make it include UTM?
Omry,
Right.  You can do any UTM projection conversion with appropriate choice of
Transverse Mercator parameters.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
