[OSRS-PROJ] EPSG: invalid projections?
Fri Oct 24 09:24:31 PDT 2003
Jan-Oliver Wagner wrote:
> On Fri, Oct 24, 2003 at 09:28:01AM -0400, Frank Warmerdam wrote:
>>I suggest you file this in bugzilla as a bug.  I would guess I am
>>incorrectly translating these coordinate systems but it will take some
>>investigation to see what is going wrong, and what should be done.
> I tried to, but am not sure wether the report made it finally into
> the bug tracker. I experienced a time-out during this process a couple
> of times.
Jan,
It does not seem to have gotten in there.  Perhaps you can try again later
and things will be more stable.
Best regards,
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
