[OSRS-PROJ] newbie; PROJ.4 for raster data?
Frank Warmerdam
warmerdam at pobox.com
Thu Sep 11 06:15:35 PDT 2003
Nando Foppa wrote:
> Hello outhere,
> I have very simple question which I couldn't answer by myself for sure,
> even when reading the manuals...
> Is't possible and recommendable to use PROJ.4 for reprojection of
> satellite (raster) data from geographic (WGS84) to swiss projection.
> What about resampling of the pixel values? Or is PROJ.4 specially used
> for reprojection of vector data?
> Thanks a lot for an answer of this simple but for me important question!
Nando,
PROJ.4 just transforms coordinates, and has no knowledge of "vectors" or
"rasters" though there are packages built on PROJ.4 for doing both. For
raster warping based on PROJ.4 you could use GDAL.
For example the following would warp a GeoTIFF file in some appropriate
input coordinate system (defined in the file) to UTM 11.
gdalwarptest -t_srs '+proj=utm +zone=11 +datum=WGS84' in.tif out.tif
GDAL can be found at:
http://www.remotesensing.org/gdal/
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
