[OSRS-PROJ] Quadrilatieralized Spherical Cube projection
Dan Stahlke
dstahlke at gi.alaska.edu
Thu Apr 1 21:32:38 PST 2004
I need to efficiently (with low distortion) divide the globe into
square tiles in order to store global images. I am currently using a
modified gnomonic projection onto a cube. The projection I am
currently using is an arctangent of the gnomonic projection (which
could also be visualized as two cylindrical projections, one for each
axis). I am using a modified version of GCTP for this, but Proj.4
looks a lot better. There doesn't seem to be any existing projection
similar to what I am using, but in the course of my research I found
out about the Quadrilatieralized Spherical Cube projection, which
sounds a lot better.
This projection is used by the COBE project to store images of the sky.
It is a projection of the sphere onto a cube and is supposed to have
distortion of less than 1%.
It looks like the Quadrilatieralized Spherical Cube projection doesn't
currently exist in Proj.4, but if needed I am willing to add it. My
question is: does this projection already exist under a different name,
or is there something else that can be used? If I add this projection,
could it be included with the main distribution?
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
