[OSRS-PROJ] Roussilhe Stereographic Projection
Gerald Evenden
gerald.evenden at verizon.net
Mon Apr 5 09:27:42 PDT 2004
A few additional notes on the stereographics:
1. +proj=sterea and +proj=rouss compare quite closely and the former
could be used by those with current libraries to handle Polish grids
if
their accuracy needs are not in the cm. range.
2. +proj=stere (of GCTP fame) produces larger differences and also has
slightly larger scale errors. If one is not replicating existing
grid systems
using +proj=stere or UPS, I would recommend +proj=sterea for oblique/
equitorial applications.
3. While doing the documentation for the stereographic it was readily
apparent
that, softwarewise, sterea should be part of the PJ_stere.c file.
Thus the next
release will be missing PJ_sterea.c. Lest anyone panic, the
+proj=sterea
entry will still be there and all operations will match previous
libraries. If
polar aspect is chosen in sterea it will resort to the same
algorithm used
in stere (which does not go through conformal sphere).
_____________________________________
Jerry and the low riders: Daisy Mae and Joshua
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
