[Proj] Compilation under Windows; DLL issues
proj-admin at remotesensing.org
Thu Apr 15 08:20:12 PDT 2004
I found, that to use the PROJ.4 library from Visual Basic, functions
also
need to use __stdcall. I wrote a simple wrapper for the 4.4.6 build:
http://ftp.dfg.ca.gov/Outgoing/Nafwb/proj4/proj_api.zip
Eric G. Miller
GIS Analyst
Wildlife and Habitat Data Analysis Branch
Department of Fish and Game
>>> proj-admin at remotesensing.org 4/15/2004 6:03:58 AM >>>
> Hi all,
> There are some issues using libproj as a DLL under Windows.
> The way the definitions currently are, it is not possible to access
> pj_errno or pj_release.
> The reasons for that are:
> *) pj_release is not defined as an export in proj.def
> *) pj_errno needs __declspec(dllimport) in its declaration to be
accessible
> The second issue is a tricky one. Methods don't need the
__declspec-stuff,
> they just get a second level of indirection in the code. Data,
however, need
> that.
Thomas,
To get access to the errno value, windows applications are expected to
call
pj_get_errno_ref() which returns a pointer to the pj_errno variable.
While
your approach can work, I decided that depending on the ability to
export
variables from the DLL/shared library was likely to be a source of
problems,
so I provided the function access.
I should have done the same for pj_release, but I wasn't aware anyone
was using
it. I have added a pj_get_release() function that will return the
pj_release
string in CVS. This will appear in the next release.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | Geospatial Programmer for
Rent
More information about the Proj
