[Proj] EPSG and ToWGS84
Paul Selormey paul at toolscenter.org
Tue Apr 20 15:21:26 PDT 2004
Thanks so much. I will study it today and see how to make
maximum use of it.
Best regards,
Paul.
----- Original Message -----
To: <proj at remotesensing.org>
Sent: Wednesday, April 21, 2004 1:04 AM
Subject: Re: [Proj] EPSG and ToWGS84
> On Tue, Apr 20, 2004 at 01:59:21PM +0900, proj-admin at remotesensing.org
wrote:
> > Hello All,
> > Please can anyone help me find the ToWGS84 values for a datum in
> > the EPSG database?
> > I have being playing with the EPSG database but still could not find
> > the ToWGS84 parameters anywhere!
> The SQL query should be something like this (I received this
> SQL statement from an EPSG team member):
> SELECT o.coord_op_name, m.coord_op_method_name, p.parameter_name,
> pu.sort_order, pv.parameter_value, u.unit_of_meas_name, a.area_name
> FROM epsg_coordoperation o
> JOIN epsg_coordoperationmethod m
> ON m.coord_op_method_code = o.coord_op_method_code
> JOIN epsg_coordoperationparamvalue pv
> ON pv.coord_op_method_code = o.coord_op_method_code AND
> pv.coord_op_code = o.coord_op_code
> JOIN epsg_coordoperationparamusage pu
> ON pu.coord_op_method_code = o.coord_op_method_Code AND
> pu.parameter_code = pv.parameter_code
> JOIN epsg_coordoperationparam p
> ON p.parameter_code = pv.parameter_code
> JOIN epsg_unitofmeasure u
> ON u.uom_code = pv.uom_code
> JOIN epsg_area a
> ON a.area_code = o.area_of_use_code
> WHERE o.coord_op_type = 'transformation' AND o.coord_op_name
> LIKE '%WGS 84%' AND o.deprecated = 0
> ORDER BY coord_op_name;
> Best regards,
>  Markus
> Proj mailing list
> Proj at remotesensing.org
> http://www.remotesensing.org/mailman/listinfo/proj
