[Proj] Different results with +ellps and +datum
Zarko Mocnik
zarko.mocnik at triera.net
Tue Apr 20 15:26:24 PDT 2004
I noticed the following bahaviour of cs2cs:
with
proj -ld
I got:
__datum_id__ __ellipse___
__definition/comments______________________________
WGS84 WGS84 towgs84=0,0,0
etc..
When I enter:
cs2cs +datum=WGS84 +proj=longlat +to +ellps=bessel +proj=longlat
+towgs84=668,-205,442
15d29'1.2737 46d36'44.7813
I got:
15d29'18.941"E 46d36'46.661"N -21.034
But if I change command line to:
cs2cs +ellps=WGS84 +proj=longlat +to +ellps=bessel +proj=longlat
I got:
15d29'1.274"E 46d36'42.631"N 704.788
I would expect the same result (the first one) in both cases.
Is this I bug or a feature?
I use cs2cs Rel. 4.4.6, 3 March 2003 (I downloaded precompiled windows
version)
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20040421/cb229668/attachment.html>
More information about the Proj
