[OSRS-PROJ] proj4 parameter question regarding UTM
Ed McNierney ed at topozone.com
Fri Feb 6 16:53:42 PST 2004
Peter -
If that's what you're looking for, you got the right answer.
You concluded that it was wrong because you compared it to the zone 7
northing and easting, not the pseudo-zone 10 values.
While you can mathematically do what you're intending, you will get
severe distortion in your data.  Using "tmerc instead" won't help - UTM
is simply a particular form of tmerc, and using tmerc for such a large
extent will produce a comparable degree of distortion.
Depending on your application, that distortion might be acceptable.  The
reason UTM zones are 6 degrees wide is based on a desire to limit the
extent of that distortion.
	- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com
-----Original Message-----
Sent: Friday, February 06, 2004 7:17 PM
To: osrs-proj at remotesensing.org
Subject: Re: [OSRS-PROJ] proj4 parameter question regarding UTM
Hello,
Yes, I want pseudo values in UTM zone 10 projection.
I guess I could make a table of meridians and use tmerc instead.
Peter
> That lat, long is in zone 7.  You are trying to get a psuedo-zone
> value, 3
zones away.
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
