[OSRS-PROJ] Lat-lon to pixel
Gerald Evenden
gerald.evenden at verizon.net
Sat Feb 7 07:07:02 PST 2004
PROJ.4 will transform between geographic and cartesian coordinate
systems but *you* must know what kind of map transformations are
involved in you pixel maps. Knowing the projection details (like
projection type, and control factors the remaining problem is knowing
scaling and rotation needed to convert from PROJ.4 cartesian system
to that of your pixel map. Also you need to be sure that PROJ.4
supports
both forward *and* inverse projection modes for the particular
projection
type your pixel map is using.
On Sep 7, 2003, at 5:44 AM, Gyula wrote:
> Hi all
> I have just downloaded the proj (the delphi version), but i dont know
> if it is useful for me. I have some scanned bitmap maps, and i want to
> use proj
> only to get the latitude longitude coordinates of the
> pixels, and vica-versa, put objects on to the bitmap using the lat-
> lon coordinates. How can I solve this with proj?
> Thanks in advance
> Jeff
_____________________________________
Jerry and the low riders: Daisy Mae and Joshua
Name: not available
Type: text/enriched
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20040207/1f979db0/attachment.bin>
More information about the Proj
