[OSRS-PROJ] Converting from WGS-84 to Sweden's RT-90
Gerald Evenden gerald.evenden at verizon.net
Tue Feb 10 08:15:21 PST 2004
PROJ.4, all versions, will accept decimal degrees:
35d7'30"
35d7.5'
25.125
are legal, equivalent input.
On Feb 10, 2004, at 11:04 AM, Frank Warmerdam wrote:
> alexander at isacson.info wrote:
>> Thank you for your quick reply.
>> I have two further questions:
>>   My GPS reciver outputs degrees and not degrees, minutes, seconds.
>> Can
>> cs2cs handle that? Can I just do "echo 58.39693 15.51353 | cs2cs
> Alexander,
> PROJ commandline utilities accept DMS angles that look like this:
> 120d1'31.122"W  27d5'23.59"N
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> PROJ.4 Discussion List
> See http://www.remotesensing.org/proj for subscription, unsubscription
> and other information.
_____________________________________
Jerry and the low riders: Daisy Mae and Joshua
