[OSRS-PROJ] Uk Grid projection
Frank Warmerdam
warmerdam at pobox.com
Tue Feb 17 07:47:11 PST 2004
Tim Sutton wrote:
> Hi
> I have two questions:
> 1) I would like to convert coordinates from UK National Grid to lat/long.
>>From the proj manual and ordinance survey information, I calculate the input
> projection definition to be:
> +proj=tmerc +lat_0=49n +lon_0=2w +k=0.9996012717 +ellps=airy +a=677563.396
> +b=6356256.910
> How would I specify that I want the output coordinates to be in lat/long using
> proj on the command line.?
Tim,
The proj command always converts between the projected coordinate system you
specify, and lat/long coordinates on the same ellipsoid. So, no need to
specify anything special.
Note, I tried your formulation which duplicates the ellipsoid information
between the +ellps and the +a/+b and got:
warmerda at gdal2200[40]% proj +proj=tmerc +lat_0=49n +lon_0=2w +k=0.9996012717 +ellps=airy +a=677563.396 +b=6356256.910
Rel. 4.4.7, 31 March 2003
<proj>:
projection initialization failure
cause: squared eccentricity < 0
program abnormally terminated
With just the following things seem to work fine:
warmerda at gdal2200[41]% proj +proj=tmerc +lat_0=49n +lon_0=2w +k=0.9996012717 +ellps=airy
By default proj converts from lat/long values to projected coordinates. To go
from projected coordinates to lat/long supply the -I (inverse) parameter.
I would add that your coordinate system definition is lacking the false easting
and north required for the British National Grid. If we use EPSG code 27700
(OSGB 1936 / British National Grid) we get:
warmerda at gdal2200[44]% proj -v +init=epsg:27700
#Transverse Mercator
# Cyl, Sph&Ell
# +init=epsg:27700 +proj=tmerc +lat_0=49 +lon_0=-2 +k=0.999601 +x_0=400000
# +y_0=-100000 +ellps=airy +units=m +no_defs
> 2) Is there a simple 'hello world' c++ example that demonstrates the libproj
> programmatic interface, as I need to do the above process programmatically.
> I am woking on suse linux 9.0
The proj_init() man page includes the following simple "old style API"
example for going from lat/long to projected coordinates.
#include <proj_api.h>
main(int argc, char **argv) {
char *args[] = { "proj=merc", "ellps=clrk66", "lat_ts=33" };
projUV p;
projPJ pj;
if (!(pj = pj_init(3, args)))
exit(1);
while (scanf("%lf %lf", &p.v, &p.u) == 2) {
p.u *= DEG_TO_RAD;
p.v *= DEG_TO_RAD;
p = pj_fwd(p, pj);
printf("%.2f\t%.2f\n", p.u, p.v);
exit(0);
To go the other way, use pj_inv() instead of pj_fwd() and apply the RAD_TO_DEG
translation to the result after pj_inv() instead of the reverse before. The
angles accepted and produced by the API entry points are always in radians.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
