[OSRS-PROJ] cs2cs and prime meridian
Markus Neteler
neteler at itc.it
Wed Feb 25 09:41:54 PST 2004
Dear list members,
I would like to report a strange (for me) observation in 'cs2cs'.
Trying to reproject from Gauss-Boaga to LatLong, I obtain somehow
odd results:
1) Gauss-Boaga/Fuso 1 (Ovest) to LatLong:
cs2cs -v +init="epsg:26591" \
+to +proj=latlong +datum=WGS84
# ---- From Coordinate System ----
#Transverse Mercator
# Cyl, Sph&Ell
# +init=epsg:26591 +proj=tmerc +lat_0=0 +lon_0=21.45233333333333 +k=0.999600
# +x_0=1500000 +y_0=0 +ellps=intl +pm=rome +units=m +no_defs
# ---- To Coordinate System ----
#Lat/long (Geodetic)
# +proj=latlong +datum=WGS84 +ellps=WGS84 +towgs84=0,0,0
1660469 5101082 100
23d31'34.538"E 46d2'37.045"N 100.000
This result is wrong.
2) Specifying the parameters manually without prime meridian:
cs2cs -v +proj=tmerc +lat_0=0 +lon_0=9 +k=0.999600 +x_0=1500000 +y_0=0 \
+ellps=intl +units=m +no_defs \
# Cyl, Sph&Ell
# +proj=tmerc +lat_0=0 +lon_0=9 +k=0.999600 +x_0=1500000 +y_0=0 +ellps=intl
# +units=m +no_defs
1660469 5101082 100
11d4'26.138"E 46d2'37.045"N 100.000
This result is correct (at least close to be correct).
3) Specifying the parameters manually *with* prime meridian:
+ellps=intl +units=m +pm=rome +no_defs \
# Cyl, Sph&Ell
# +units=m +pm=rome +no_defs
1660469 5101082 100
4) Specifying the parameters manually with *wrong* prime meridian:
+ellps=intl +units=m +pm=ferro +no_defs \
# Cyl, Sph&Ell
# +units=m +pm=ferro +no_defs
1660469 5101082 100
Same results with +pm=ferro and +pm=rome, strange.
5) Test again, using nonsense +pm value:
+ellps=intl +units=m +pm="99.999" +no_defs +to +proj=latlong +datum=WGS84
# Cyl, Sph&Ell
# +units=m +pm=99.999 +no_defs
1660469 5101082 100
To me this indicates that all specifications of the prime meridian in
the epsg file are ignored by 'cs2cs'. Since some month ago, when the
lon_0 values were adapted to introduce the concept of prime meridian,
all calculations based on these epsg entries are wrong (tested only 'rome'
pm).
Number of potentially affected definitions:
grep '+pm=' /usr/local/share/proj/epsg | wc -l
66
Please tell me that I am wrong (where's the trick?).
Sorry, if this was a stupid observation, but I don't manage
to use 'cs2cs' any more for Gauss-Boaga.
Otherwise, should I file a bug report?
See also related bug report in GDAL Bugtracker: "gdalwarp 900km off"
http://bugzilla.remotesensing.org/show_bug.cgi?id=367
Kind regards
Markus Neteler
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
