[OSRS-PROJ] towgs84
Frank Warmerdam
warmerdam at pobox.com
Fri Feb 27 07:14:29 PST 2004
Igor Alfirevic wrote:
> Hi!
> If i include paramter +towgs84 in proj.exe
> ther is no efect. Why??
> proj +proj=utm +ellps=intl +towgs=100,200,300 +zone=33
Igor,
The proj program specifically converts between a projection and the
lat/long coordinates on the same ellipsoid. It ignores any "auxilary"
information like datum or prime meridian. So the +towgs84 information is
not significant since it never attempts to convert to/from wgs84.
As I presume you have since discovered, the cs2cs program is more appropriate
for conversion between arbitrary coordinates systems.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
