[OSRS-PROJ] Error projecting Geographic to UPS
Frank Warmerdam
warmerdam at pobox.com
Wed Jan 7 12:29:25 PST 2004
Charles D. Van Dusen wrote:
> Greetings
> I am having a problem projecting a shapefile of canada from geographic
> to UPS:
> P:\Data\maproom.psu.edu>shpproj canada.shp projections\ups\canada.shp
> -i=geographic -o"proj=ups"
> The program appears to complete without error, but the resulting .prj
> file has a single line of "proj=geographic" and the output shape file is
> exactly the same as the input shape file.
> So, in stepping though the debugger, the problem appears to be that the
> SHPSetProjection call is returning 0 for the new_prj. Further, the call
> to pj_init in shpgeo.c is returning 0 as well.
> My environ:
> Windows XP
> shapelib-1.2.10
> proj cvs as of December 2003
Charlie,
My understanding is that there are four UPS zones, and you aren't indicating
which to use. I would gather that the pj_init() is therefore failing because
it doesn't have all the required arguments.
I haven't dug into the PROJ docs to find what the correct formulation is for
UPS, but I presume that is the issue.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
