[OSRS-PROJ] Geocentric systems and ellipsoids
Frank Warmerdam
warmerdam at pobox.com
Tue Jan 13 06:03:49 PST 2004
czaht at ocag.ch wrote:
> Hi,
> I have a question regarding the handling of geocentric system libproj. It
> seems that I need to define an ellipsoid together with a geocentric system,
> in my case the WGS84 Cartesian
> system. Why?
> In my opinion, a geocentric system is defined by the centre of the earth and
> a rotation relative to the WGS84 Cartesian system.
> Could someone shed a bit of light on this matter?
Thomas,
The geocentric support in PROJ.4 (as opposed to Gerald's newer libproj4)
is quite new and somewhat experimental. The need for an ellipse is really
an artifact of internal assumptions of the library before geocentric support
was added.
Just select the same ellipsoid/datum as the output coordinate system you
will be transforming to (or the input system you are transforming from).
You are correct that the geocentric coordinates define the location without
any real need for an ellipse.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
