[OSRS-PROJ] Rectified Skew Orthomorphic...
Carl Godkin carl at dgi.com
Thu Jan 15 21:01:21 PST 2004
Gerald Evenden wrote:
> I have been through all the nonsense with the Malayan Monster and
> even added some parameters to PROJ.4 omerc to do the necessary
> supplemental operations.  HOWEVER, that was a long time ago and
> I will have to revisit the scene of the crime and see if I can figure how
> to use them again.
As requested, I added my "diffs" to the bugzilla database
(http://bugzilla.remotesensing.org/show_bug.cgi?id=461)
so you and other victims of this projections may inspect
my idea for supporting it.
> Please give me a couple of days as I have some other stuff going on.
> Part of the problem is reading FAXes of the details which are of
> very poor quality.
By the way, I'm working from a fax copy myself.
The funny thing is that someone helpfully summarized it in
the form of a Word document and made two typos doing so. I
only found them after I questioned our client on the unlikely
shape of the earth they provided.  That's when I saw the
fax with presumably correct values.
I've got a working solution for my purposes, so please take
all the time you need.
carl
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
