[SPAM] - Re: [OSRS-PROJ] Projection information for DCW - Email found in subject
Charles D. Van Dusen
charlie at im-design.net
Mon Jan 19 07:21:36 PST 2004
I retrieved data from the DCW server at penn state university.
They pre-process Russia and Antarctica (so they are not available in
decimal degrees).
Can you suggest any other source for DCW data?
-----Original Message-----
[mailto:owner-osrs-proj at remotesensing.org] On Behalf Of Frank Warmerdam
Sent: Monday, January 19, 2004 9:32 AM
To: osrs-proj at remotesensing.org
Subject: [SPAM] - Re: [OSRS-PROJ] Projection information for DCW - Email
found in subject
Charles D. Van Dusen wrote:
> Hello all:
> I am workign with DCW data which Ive downloaded. Id like to project
> antarctica and russia, but the data are sourced in something other
> than decimal degrees.
> Can anyone provide me with the parameters of the projection in which
> these data exists within the DCW?
Charles,
To the best of my knowledge all DCW data (as distributed by NIMA
anyways) is in WGS84 decimal degrees. What was your data source? Why
do you think it isn't decimal degrees? I think you are going to need to
go back to your source, or find some metadata with info.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | Geospatial Programmer for Rent
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
