[OSRS-PROJ] SOM-A
Gerald Evenden
gerald.evenden at verizon.net
Fri Jan 23 12:40:13 PST 2004
Space obl.. merc is in PROJ.4, basically a copy of gctp.
+proj=lsat
On Jan 23, 2004, at 3:04 PM, Frank Warmerdam wrote:
> Folks,
> Some folks from JPL are interested in having SOM-A added to GeoTIFF.
> However, the arguments they propose for it are not ones that I am
> familiar
> with and I wonder how practical they would be to use. Does anyone
> know if
> PROJ.4 supports Space Oblique Mercator (specially form-A from GCTP)?
> Would anyone be interested in implementing it?
> The JPL proposal looks like this:
> Michael A. Bull wrote:
> > To all,
> > I would like to see support added for the Space Oblique Mercator
> (SOM) projection in
> > GeoTiff. Specifically, I'm interested in the generic SOM format A,
> as defined by GCTP,
> > and also is implemented in ENVI version 4.0. The parameters
> required to define the
> > SOM format A projection are as follows:
> > 1 Semi-major axis of the ellipsoid
> > 2 Semi-minor axis of the ellipsoid
> > 3 Inclination of orbit ascending node. (angular units)
> > 4 Longitude of ascending orbit at equator. (angular units)
> > 5 False easting
> > 6 False northing
> > 7 Period of satellite revolution. (time in minutes)
> > 8 Satellite ratio. This controls the start and end points of the
> map on
> > the earth surface.
> > I propose that a new projection type be added along with keys for the
> > projection parameter types that are not already supported.
> > Following existing convention, I suggest the projection type should
> be named
> > CT_ObliqueMercator_Space_A
> > New projection parameter keys are needed for parameters 3,4,7 and 8
> (above).,
> > The other parameters already have appropriate keys defined.
> Suggested new
> > parameter type names are
> > 3 ProjInclinationAscending
> > 4 ProjLongitudeAscending
> > 7 ProjOrbitPeriod
> > 8 ProjSatelliteRatio
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> PROJ.4 Discussion List
> See http://www.remotesensing.org/proj for subscription, unsubscription
> and other information.
_____________________________________
Jerry and the low riders: Daisy Mae and Joshua
More information about the Proj
