[OSRS-PROJ] Bug in CEA projection?
Gerald Evenden
gerald.evenden at verizon.net
Wed Jan 28 07:18:43 PST 2004
Local lproj (libproj4) script:
../lproj +proj=cea +ellps=WGS84 +lat_ts=30 -I -f '%.6f'<<EOF
0 7284713.234
EOF
Produces the following results:
0.000000 82.855347
Older versions of proj seem to have a problem. Last change
to cea (libproj4) was Mar., '03
On Jan 28, 2004, at 6:00 AM, Orme, David wrote:
> Hi,
> This was cross-posted from the Grass list a while back - have I got
> something wrong or is this a bug?
> I'm using Proj 4.4.7 on my Mac 10.3.2 and ArcGIS 8 on a Windows XP
> machine - the two programs give different answers for coordinate
> transformations into a Behrmann projection (Cylindrical Equal Area
> with latitude of true scale at 30 N/S). I've checked using Geotrans
> 2.2.4 on the Windows machine and that agrees with ArcGIS.
> My test point is in Behrmann coordinates, units in meters: 0E
> 7284713.234N
> cs2cs gives:
> > doibook:~/Library/Preferences dorme$ cs2cs -f "%0.6f" +proj=cea
> > +lat_ts=30 +datum=WGS84 +to +proj=latlong +datum=WGS84
> > 0 7284713.234
> > 0.000000 82.485563 0.000000
> Both ArcGIS and Geotrans give the following geodesic coordinates: 0 E
> 82.855347 N
> Any suggestions?
> Many thanks,
> David Orme
_____________________________________
Jerry and the low riders: Daisy Mae and Joshua
Name: not available
Type: text/enriched
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20040128/3b3760e9/attachment.bin>
More information about the Proj
