[Proj] Lat/Long to lcc
Al McCaig
projgis at mchaggis.org.uk
Thu Jul 1 04:09:56 PDT 2004
I am trying to convert Lat/Long coords to Lamberts using proj and am
having a few problems, ie it doesn't seem to give the correct results.
I have the following information but am slightly unsure how to use it in
proj:
Projection:
Geodetic Datum (Speriod): WGS84
Units: meters
Central meridian: 5deg east
Central Parallel: 49.08516574deg north
1st Standard Parallel: 44deg north
2nd Standard Parallel: 54deg north
False Easting (X): 1507373
False Northing (Y): 1607866
I also have a set of data which contain Lat/Long and the Lamberts coords
as the above projection data, two of these are:
53.333889, -1.968552 => 1044152, 2100526
53.334186, -1.968341 => 1044169, 2100558
Any help would be grateful.
Al,
Yes, maybe life sucks, but at least I don't have to use Windows!
More information about the Proj
