[Proj] minor proj bugs
Wed Jul 28 16:31:46 PDT 2004
Britton Kerin wrote:
> Hello,
> Not sure this list is alive (the archive link on the web page doesn't
> work).  The web interface to bugzilla isn't working either though, so here
> goes:
Britton,
Have have removed the old archive link and noted that the subscribe/unsub
link also leads to archives.
> 1. There is a discrepency between the pj_geocentric_to_geodetic
>    and pj_geodetic_to_geocentric prototypes in proj_api.h and the
>    corresponding definitions in pj_transform.c.  The second argument in
>    the signatures in the definitions is 'es', which I assume stands for
>    eccentricity squared.  The first thing the functions do is compute 'b'
>    (I assuem the minor axis treating es as eccentricity squared, so I
>    guess eccentricity squared s what it is.  The prototypes in proj_api.h
>    have a second argument called 'ra' however, which is confusing.  It
>    looks to me like the names in proj_api.h should be changed from 'ra' to
>    'es'.
Agreed.  I have fixed this in CVS.
> 2. The description of the -format option in the cs2cs man page contains an
>    unecesary sentence:
>               Format is a printf format string to  con-
>               trol  the form of the output values.  For
>               inverse projections, the output  will  be
>               in  degrees when this option is employed.
>               If a format is specified for inverse pro-
>               jection  the output data will be in deci-
>               mal  degrees.   The  default  format   is
>               "%.2f" for forward projection and DMS for
>               inverse.
Fixed in CVS.
> 3. Advertise the new general transformation capabilities (cs2cs and
>    corresponding capabilities of 'projPJ' type in library) better!  They
>    are really cool and I almost missed them entirely.
Advertise where?  I can't update the postscript/pdf manuals as they are "readonly"
at this point.  But the new stuff is listed in the pj_init man page and cs2cs
has a SEE ALSO'ed man page.
> 4. Some of the API routines look redundant with each other now.  For
>    example, if I understand correctly: pj_datum_transform is now subsumed
>    into pj_transform?  And pj_fwd and pj_inv are also simple versions of
>    pj_transform?  This redundance should probably be discussed somewhere
>    to prevent confusion.  Or, if they are different, the differences
>    should be described.
pj_transform() is built by using the various component transformations.  The
pj_datum_transform() isn't really intended to be too public, and I don't
think I have documented it anywhere.
> proj is excellent in general though, definately worth keeping it up to
> speed and polishing up the docs.
Thanks,
