[Proj] wrong values for shift utm ed50 to utm wgs84
Markus Neteler
neteler at itc.it
Mon Jun 21 06:59:48 PDT 2004
On Thu, May 27, 2004 at 08:06:56AM +0200, Christoph Dohmen wrote:
> Hi all,
> I have to translate several values from utm ed50 to utm wgs84. I tried this
> with several tools and got different values :-( And especially using cs2cs I
> got definitly _wrong_ values. Just an example:
> values to translate as metre values from zone 32 north in ed50:
> 488000 E
> 5902000 N
> using the demo-version of transdat I get the following:
> 487916.915498 E
> 5901796.048890 N
> using the online-tool from http://www-ipf.bau-verm.uni-karlsruhe.de/cgi-bin/
> trafo.tcl I get:
> 487921.76 E
> 5901788.00 N
> and using cs2cs (from proj 4.4.8) I get:
> 488000.00 E
> 5902000.00 N
> with the params: cs2cs +proj=utm +ellip=intl +to +proj=utm +ellip=WGS84
> +datum=WGS84 << EOF
> > 488000 5902000
> > EOF
It should be ellps, not ellip, I think.
Hint: Use the -v flag to see which parameters are really used.
> using cs2cs +proj=utm +a=6378388.0 +b=6356911.94613 +zone=32 +to +proj=utm
> +ellps=WGS84 +zone=32 << EOF with the same values result in:
> 488000.36 E
> 5901787.27 N
> and cs2cs -v +init=epsg:23032 +to +init=epsg:32632 << EOF for the above
> mentioned point results also in:
> 488000.36 E
> 5901787.27 N
> >From several sources I read the there should be an offset in germany from
> round about -80m east and -200m north. Those values are 'nearly' calculated
> by the first two tools. But using cs2cs there is an offset of +0.36m east and
> -212.73m north. The northing offset seems to look allright but the easting
> offset must be wrong.
> So, what is the mistake I made? Wrong params for cs2cs??
> Can anyone help me or even just give me a hint how to translate utm ed50 to
> utm wgs84?
It seems that you are missing the ED50 Datum (here the "whole country" Potsdam datum):
cs2cs -v +init=epsg:23032 +towgs84=598.1,73.7,418.2,0.202,0.045,-2.455,6.70 +to +init=epsg:32632
# ---- From Coordinate System ----
#Universal Transverse Mercator (UTM)
# Cyl, Sph
# zone= south
# +init=epsg:23032 +towgs84=598.1,73.7,418.2,0.202,0.045,-2.455,6.70
# +proj=utm +zone=32 +ellps=intl +units=m +no_defs
# ---- To Coordinate System ----
# Cyl, Sph
# zone= south
# +init=epsg:32632 +proj=utm +zone=32 +ellps=WGS84 +datum=WGS84 +units=m
# +no_defs +towgs84=0,0,0
#--- following specified but NOT used
# +ellps=WGS84
488000 5902000
487930.33 5901554.44 930.44
You may want to select the appropriate Potsdam datum for your zone.
Hope this helps
Markus
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
More information about the Proj
