[myjunk] [Proj] compilation faults in PROJ4
Sam Harrell sammyh at 3rddim.com
Tue Jun 1 07:35:33 PDT 2004
>> I have no experience in installing from source.
The distributions of proj includes pre-compiled executables, libraries and a
dll to link to.  See projects.h and proj_api.h for function prototypes.
Sorry, can't help with build errors.
-----Original Message-----
From: proj-admin at remotesensing.org [mailto:proj-admin at remotesensing.org] On
Behalf Of Maciek Sieczka
Sent: Sunday, May 30, 2004 1:38 PM
To: proj at remotesensing.org
Subject: [myjunk] [Proj] compilation faults in PROJ4
Hi all!
I installed PROJ.4 (Rel. 4.4.8 2004-05-04) from source but in the log files
I found plenty of errors and warnings.
Could someone help me? My questions are:
1. are these errors serious?
2. what may be the reasons?
3. how do I get rid of them?
Forgive me please if I'm waisting your time. I have no experience in
installing from source. It's my first attempt.
My Linux is Mandrake 9.2, GCC 3.3.1, kernel 2.4.22-26mdk, bison-1.875.
Should I provide any more info please tell me.
Listed below are faults extracted from log files. COMPLETE "./configure" and
"make" logs are attached.
./configure errors:
configure:2651: gcc -c -g -O2  conftest.c >&5
conftest.c:2: error: syntax error before "me"
configure:2657: $? = 1
configure: failed program was:
| #ifndef __cplusplus
|   choke me
| #endif
./configure warnings:
configure:5362: checking if gcc supports -fno-rtti -fno-exceptions
configure:5384: gcc -c -g -O2 -fno-rtti -fno-exceptions -c conftest.c
conftest.c >&5
cc1: warning: "-fno-rtti" is valid for C++ but not for C/ObjC
configure:7955: checking for exp in -lm
configure:7985: gcc -o conftest -g -O2   conftest.c -lm   >&5
conftest.c:29: warning: conflicting types for built-in function `exp'
./configure other "failed":
configure:3796: gcc -E  conftest.c
conftest.c:11:28: ac_nonexistent.h: No such file or directory
configure:3802: $? = 1
| /* confdefs.h.  */
| #define PACKAGE_NAME ""
| #define PACKAGE_TARNAME ""
| #define PACKAGE_VERSION ""
| #define PACKAGE_STRING ""
| #define PACKAGE_BUGREPORT ""
| #define PACKAGE "proj"
| #define VERSION "4.4.8"
| /* end confdefs.h.  */
| #include <ac_nonexistent.h>
configure:3841: result: gcc -E
configure:3865: gcc -E  conftest.c
configure:3871: $? = 0
configure:3903: gcc -E  conftest.c
configure:3909: $? = 1
| /* confdefs.h.  */
configure:5142: checking if gcc static flag -static works
configure:5166: gcc -o conftest -g -O2   -static conftest.c  >&5
/usr/bin/ld: cannot find -lc
collect2: ld returned 1 exit status
configure:5172: $? = 1
| /* confdefs.h.  */
| #define STDC_HEADERS 1
| #define HAVE_SYS_TYPES_H 1
| #define HAVE_SYS_STAT_H 1
| #define HAVE_STDLIB_H 1
| #define HAVE_STRING_H 1
| #define HAVE_MEMORY_H 1
| #define HAVE_STRINGS_H 1
| #define HAVE_INTTYPES_H 1
| #define HAVE_STDINT_H 1
| #define HAVE_UNISTD_H 1
| #define HAVE_DLFCN_H 1
| int
| main ()
|   return 0;
make warnings:
gcc -DHAVE_CONFIG_H -I. -I. -I. -DPROJ_LIB=\"/usr/local/share/proj\" -g -O2
-c pj_ellps.c -MT pj_ellps.lo -MD -MP -MF
.deps/pj_ellps.TPlo  -fPIC -DPIC -o .libs/pj_ellps.lo
pj_ellps.c:9: warning: `pj_ellps' initialized and declared `extern'
-c pj_errno.c -MT pj_errno.lo -MD -MP -MF
.deps/pj_errno.TPlo  -fPIC -DPIC -o .libs/pj_errno.lo
pj_errno.c:8: warning: `pj_errno' initialized and declared `extern'
-c pj_units.c -MT pj_units.lo -MD -MP -MF
.deps/pj_units.TPlo  -fPIC -DPIC -o .libs/pj_units.lo
pj_units.c:11: warning: `pj_units' initialized and declared `extern'
-c pj_datums.c -MT pj_datums.lo -MD -MP -MF
.deps/pj_datums.TPlo  -fPIC -DPIC -o .libs/pj_datums.lo
pj_datums.c:70: warning: `pj_datums' initialized and declared `extern'
pj_datums.c:89: warning: `pj_prime_meridians' initialized and declared
`extern'
O2 -c `test -f 'nad2nad.c' || echo './'`nad2nad.c
nad2nad.c: In function `main':
nad2nad.c:229: warning: return type of `main' is not `int'
O2 -c `test -f 'nad2bin.c' || echo './'`nad2bin.c
nad2bin.c: In function `main':
nad2bin.c:13: warning: return type of `main' is not `int'
