[Proj] Help with multiply defined globals in Proj4 - Mac
bsupnik bsupnik at xsquawkbox.net
Thu Jun 24 18:41:26 PDT 2004
Hi Y'all,
First of all, thanks Gerald Evenden, Niles Ritter and Frank Warmerdam
for libGeoTiff and Proj4...I'm working on decoding Geotiff images and
their coordiantes and they're a life saver, especially for UTM->geo
conversion.
Anyway, here's my compile issue...since I'm working in a Mac IDE I'm not
using the unix makefiles, which may be how I got into trouble:
geodesic.h defines a few global variables:
n_alpha, n_S;
	double
to_meter, fr_meter, del_alpha;
And is then included in multiple translation units.  Since they are not
externed and not initialized, my compiler can't tell which declaration
is the master one, and I am getting a duplicate definition link error.
What is the correct way to solve this?  Should I have all of the
translation units (geod_for.c, geod_inv.c, geod_set.c) or do I only need
some of them?  Should I simply declare them extern?
Thanks!
Ben
