[OSRS-PROJ] Unknown USSR projection
Clifford J Mugnier cjmce at lsu.edu
Mon Mar 8 06:24:09 PST 2004
The late John P. Snyder co-authored a book on Russian projections with a
Bugayevsky.  It is published by the University of Chicago Press.  That is
the best source of clure in English that I can think of.
Cliff Mugnier
LOUISIANA STATE UNIVERSITY
I wondered if anybody can help me identify a projection. I need to
digitize some range maps from a book on the birds of the USSR: all the
maps share the same basemap but the book itself contains no projection
details. The image is on the web:
http://www.bio.ic.ac.uk/research/iowens/orme/FlintMap.png.
The only latitude or longitude mark on the map is the arctic circle: as
far as I can make out this is an arc from a circle, although there is a
hint that at the edges of the map the arc may turn down away from the
circle. I've tried identifying 10 degree lines of latitude and
longitude from locations around the map edge and that suggests to me
that the map is projected on something like a equidistant conic or
albers projection. What I've got so far:
* the central meridian is around 105 E.
* the longitude lines look like they converge on the centre of the
circle, although if I try and draw them in from geography, they don't
converge very well.
* a degree of longitude is about 0.4 degrees of arc on the projected
map.
* the latitude lines don't seem to be equally spaced - in particular,
the 80-70 N gap is wider than the other three latitudinal spacings.
I can't get it to fit - has anyone got any suggestions for projections
or projection parameters? It doesn't help that I suspect the map is
rather inaccurately drawn.
Thanks,
David
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
