[OSRS-PROJ] Unknown USSR projection
David Orme
d.orme at imperial.ac.uk
Tue Mar 9 01:46:48 PST 2004
Thanks to everyone for hints and help so far. Just to be clear, I have
added the 10 degree lat/long lines - the only lat/long mark on the
original is the dotted line of the arctic circle. The latitudes are
centred on the best fit circle I could find to the the arctic circle
curve and the longitudes radiate from there - they aren't perfect but
they are close enough to suggest that the map is some form of conic.
Cheers,
David
On 8 Mar 2004, at 16:38, Gerald Evenden wrote:
> Looking at it with dividers and a ruler it looks to be a conic and
> spacing
> of parallels eliminates equidistant. The parallels are at 10 degree
> intervals.
> but the longitude appears to be at 10 degree intervals as well but I
> find
> odd discrepancies when comparing locations of the inland seas and
> arctic islands with an old Goode atlas. Soviet disinformation,
> maybe?? ;-)
> From what can be seen from the spacing of the parallels I would guess
> conformal so try Lambert Conformal Conic (lcc) as a first guess with
> tangential latitude near the center. Scaling will be trial and error.
> PS: a lot of Soviet map projections are covered by Maling in "A Review
> of Some Russian Map Projection" in addition to the aforementioned
> Snyder
> reference.
>> I wondered if anybody can help me identify a projection. I need to
>> digitize some range maps from a book on the birds of the USSR: all
>> the maps share the same basemap but the book itself contains no
>> projection details. The image is on the web:
>> http://www.bio.ic.ac.uk/research/iowens/orme/FlintMap.png.
>> The only latitude or longitude mark on the map is the arctic circle:
>> as far as I can make out this is an arc from a circle, although there
>> is a hint that at the edges of the map the arc may turn down away
>> from the circle. I've tried identifying 10 degree lines of latitude
>> and longitude from locations around the map edge and that suggests to
>> me that the map is projected on something like a equidistant conic or
>> albers projection. What I've got so far:
>> * the central meridian is around 105 E.
>> * the longitude lines look like they converge on the centre of the
>> circle, although if I try and draw them in from geography, they don't
>> converge very well.
>> * a degree of longitude is about 0.4 degrees of arc on the projected
>> map.
>> * the latitude lines don't seem to be equally spaced - in particular,
>> the 80-70 N gap is wider than the other three latitudinal spacings.
>> I can't get it to fit - has anyone got any suggestions for
>> projections or projection parameters? It doesn't help that I suspect
>> the map is rather inaccurately drawn.
>> Thanks,
>> David
>> PROJ.4 Discussion List
>> See http://www.remotesensing.org/proj for subscription, unsubscription
>> and other information.
> _____________________________________
> Jerry and the low riders: Daisy Mae and Joshua
More information about the Proj
