[OSRS-PROJ] Roussilhe Oblique Stereographic
werchowyna at pf.pl
werchowyna at pf.pl
Fri Mar 12 04:55:14 PST 2004
hi Gerald
I'll write you again today in answer to your most recent email after I check some stuff regarding the old Frenchman and come back to my mind, cause as for now I'm too puzzled with the proj stuff :[].
In the meanwhile here are the papers I mentioned. Instead of sending them to you only links because most of them I have only in hardcopy.
Be carefull as there are almost always other Polish systems mentioned which may be confusing.
the best PL-ENG dict: http://www.translate.pl/
Those more mathematic go first:
http://www.atomnet.pl/~geodeta/2000/64text2.htm
http://www.navi.pl/produkty/ssl/uklady/uklady.html
http://www.geonet.net.pl/gfx/pliki/uklady_lokalne.doc
http://www.syryjczyk.krakow.pl/turystyka_i_gps.htm - a site on GPS in relation to Polish systems, instructions on how to apply the Roussilhe projection (called QSR here) using the Transverse Mercator, but with a significant systematic error; HE IS THE GUY I MENTIONED WHO YOU CAN TALK TO!; the site accidently out of service in the moment I'm writing to you, let's hope not anymore
http://www.northpoint.com.pl/tra65.htm
http://www.northpoint.com.pl/tra00.htm - nice diagram of transformations between different Polish grids
http://www.malopolska.pl/NR/rdonlyres/ezsnscmmace2iqdd5g73xlimsj432xnrqhevlx4bwgo75gtfutxbwbk74p7d4ekfqinh37n2coylpb/naszeuklady3.pdf - WHAT DO YOU THINK ABOUT THIS: THE GUY HERE CALLS THE 1965's ROUSSILHE PROJECTION A "THREE-STEP STEREOGRAPHIC"?
http://www.lasypanstwowe.gov.pl/sip/Szkole/podre/V.pdf - mainly pages 36-39
http://uklady_wspolrzednych.webpark.pl/index12.html
http://crs.ifag.de/crs_national.php - probably you know it
cheers
Maciek Sieczka
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
