[OSRS-PROJ] Re: Datum shifting problem
Frank Warmerdam
warmerdam at pobox.com
Tue Mar 16 20:50:12 PST 2004
Igor,
Melita Kennedy (ESRI) has kindly pointed out that +es is eccentricity squared
while you appear to be using a flattening value for the parameter:
You wrote:
>Flattening +es=0.00336700336700273
From Page 9 of of90-284.pdf the earth figure parameters are:
a - semimajor axis
b - semiminor axis
f - flattening
rf - reciprocal flattening (1/f)
e - eccentricity
es - eccentricity squared
Perhaps you should have specified +f=0.00336700336700273?
I don't know if this is your problem, but certainly it would potentially
have a radical effect on your earth figure if you use the wrong parameter.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
