[OSRS-PROJ] Schreiber Transverse Mercator
Gerald Evenden
gerald.evenden at verizon.net
Fri Mar 26 07:39:35 PST 2004
After shelving the Roussilhe for the moment I shifted back to trying to
find more
information on the even more elusive Schreiber Transverse Mercator
projection.
While googling thought a desperate selection choice and 8,000 results I
hit
upon GPSmanhttp://www.ncc.up.pt/~mig/gpsman.html wherein lay a tcl
procedure to "Schreiber Stereographic."
This turned out to be the same as libproj4's +sterea (Alternate
Stereographic)
projection which is a double conversion through the Gauss sphere. I
could
not pin down the creators source for the name but it seems to indicate
that
Schreiber had a thing for the double conversion and may have applied it
to
the Transverse Mercator problem as well. Snyder in "Flattening the
World"
describes the Schreiber as a double conversion.
The next release of libproj4 will contain the "stmerc" projection
tentatively
called the Schreiber Transverse Mercator. As Snyder indicated, the
scale
error is not zero along the central meridian but from what I find,
follows a
rather bizarre path.
_____________________________________
Jerry and the low riders: Daisy Mae and Joshua
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
