[Proj] Local Projection Selection
Patrick Mézard
pmezard at gmail.com
Sun Aug 7 12:47:38 PDT 2005
Gerald I. Evenden wrote:
> On Sun, 2005-08-07 at 18:02 +0200, Patrick Mézard wrote:
>>longitude of natural origin would be the projection center point.
>>Remains the scale factor. I could let it at 1.0. But maybe there is a
>>way to generate it programmatically given a center point, and ellipsoid
> Assuming that most of the points are within so many meters (ie. 50m)
> of the central point
> (lat_0, lon_0) then select a k_0 factor that would make the scale factor 1
> half way between the center point and projection limit. The center's
> true scale will be
> somewhat larger than 1. and the rim slightly smaller. Start with
> about +k_0=.99999 .
> Use the -V option to experiment.
> If you are keeping within 50km. scale errors should probably kept to
> within much better than 1 part in
> 100000 or close to your 2/3 meter.
Ok, and how do I compute the "real" scale factor? By comparing the
"projected" and geodesic distance of two points ? It would make sense
and given the geodesic functions in PROJ.4, I could generate the k_0
from any defined limit radius with some kind of minimization heuristic.
But you are right, I will stay with k_0=1.0 for now.
>>and a working area radius. It probably does not worth the pain however.
>>Are the output coordinate units naturally in meters or have I missed
>>other parameters ?
> The Cartesian coordinates are the same as the ellipsoid major axis
> units. If 'a' is in
> meters then the x-y values are in meters. There is also a scaling
> parameter.
Great, thank you.
Patrick Mézard
More information about the Proj
