[Proj] Extent of mercator
Dean C. Mikkelsen
dcmikkelsen at shaw.ca
Tue Aug 9 14:32:26 PDT 2005
Hi there.
Generally the same rules apply for the Mercator Projection as for the
UTM.
The largest distortion appears at the poles. To avoid the most
distortions, avoid using Latitudes greater than 60 degrees North or
South. At these latitudes, most large government agencies and countries
turn to Conic Projections.
Cheers,
Dean
Dean C. Mikkelsen, B.Sc., P.Eng.
Terra ETL Ltd - Geodesy & GIS
Phone: 604-929-8630
E-mail: dcmikkelsen at shaw.ca
-----Original Message-----
[mailto:proj-bounces at lists.maptools.org] On Behalf Of Stefan Biegger
Sent: Tuesday, August 09, 2005 9:36 AM
To: proj at lists.maptools.org
Subject: [Proj] Extent of mercator
Hi everybody
does somebody knows if there's a well defined limit of the extent when
using the mercator projection? For UTM, there's something like 'Latitude
from 84S to 80N'
Thanks a lot
Stefan
Proj mailing list
Proj at lists.maptools.org http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
