Fwd: [Proj] Robinson discrepancy btwn proj and cs2cs
Frank Warmerdam
fwarmerdam at gmail.com
Wed Aug 17 11:11:16 PDT 2005
On 8/17/05, William K <woklist at charter.net> wrote:
> From proj 4.4.7 to 4.4.8 something changed so I get different
> projected coordinates for the Robinson projection now. I didn't
> think to check cs2cs before - I noticed it in GRASS. But after
> checking cs2cs, I see that it matches GRASS, so it doesn't appear to
> be a GRASS problem.
> Here's what I get with proj 4.4.7:
> Sumomo:~ williamk$ proj +proj=robin +ellps=WGS84
> 0 45
> 0.00 4805073.65
> ^C
> Sumomo:~ williamk$ cs2cs +proj=longlat +ellps=WGS84 +to +proj=robin
> +ellps=WGS84
> 0 45
> 0.00 4805073.65 0.00
> ^C
> And here's what I get with proj 4.4.9:
> 0 45
> 0.00 4805073.65
> ^C
> +ellps=WGS84
> 0 45
> 0.00 4785120.02 -10647.46
> ^C
> There is a ~20000m Y difference. (X coordinates are not affected)
> The only other software I can check against is MAPublisher 5 for
> Illustrator. It produces the same results as the proj command. I
> had other problems with Robinson in ArcGIS, so I don't know what that
> does. (That was Arc 8, I'll have our GIS guy try it again in Arc 9
> when he gets back.)
> Which is right? How do I tell - are there some reference coordinates
> to check?
William,
I believe the issue is that Robinson is a spherical-only projection.
So internally the ellipsoid is changed from WGS84 to a sphere.
The cs2cs command notices that the two coordinate systems have
different earth models, and applies a sphere to ellipsoid conversion
as part of the operation.
The ellipsoid to ellipsoid conversion approach changed in a
fairly recent PROJ.4 library release, hence the dfference. In
the past, if there was no datum shifting information, lat/long values
were treated unchanged when going from raw ellipse to raw ellipse.
I am considering changing the "new" behavior, since it seems to
different from what most other systems do, and what people expect.
Feedback on this idea is welcome.
PS. I have rerouted this email to proj at lists.maptools.org, and I have
completely removed the proj list from xserve.flids.com.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the Proj
