[Proj] Proj binary input and output
pw
p.willis at telus.net
Fri Aug 19 10:39:00 PDT 2005
Hello,
The documentation for proj states binary input is
expected to be system byte order and double.
I am getting invalid results with binary
input, yet if I manually enter lonlats asking
for binary output I get the expected output.
Right my data is double precision floating point (64bit)
organized as a series of lonlats (x then y).
Byte order appears to be OK since the program chokes if I
reverse the byte order.
What format does my binary input file (binary_file.bin)
need to be in for the following conversion?
proj +proj=utm +zone=18 +ellps=WGS84 -i binary_file.bin
Thanks for any insights you may have,
Peter Willis
More information about the Proj
