[Proj] GRS80 vs GRS80 +towgs84=0,0,0
Maciek Sieczka werchowyna at epf.pl
Sat Dec 3 11:53:46 PST 2005
I've encountered one small thing using cs2cs I don't understand. There
is a difference in results when converting between WGS84 and GRS80 based
systems - when the towgs84=0,0,0 is given for GRS80 and when it is not:
cs2cs -f "%.6f" +proj=latlong +ellps=WGS84 +to +proj=tmerc +lat_0=0
lon_0=19 +k=0.9993 +x_0=500000 +y_0=-5300000 +ellps=GRS80 +towgs84=0,0,0
17d01'0.0E 51d07'0.0N
361227.112181   362969.278159 0.000063
But, if I don't specify the +towgs84=0,0,0 in the target coordinate
system, I obtain a slightly different result:
+lon_0=19 +k=0.9993 +x_0=500000 +y_0=-5300000 +ellps=GRS80
361227.112178   362969.278057 0.000000
The difference is less than 1 mm, but anyway - why? I thought that no
matter if I specify the towgs84=0,0,0 for GRS80 or not I would obtain
the same results.
Maciek
Historia, która przeros³a fikcjê. Chcesz poznaæ rozwi±zanie jednej z najwiêkszych tajemnic II wojny ¶wiatowej?
Przeczytaj BURSZTYNOW¡ KOMNATÊ, Catherine Scott-Clark, Adrian Levy
http://www.rebis.com.pl/rebis/strony/pokaz_ksiazke.html?id=32787
