[Proj] Patch
Martin Vermeer martin.vermeer at hut.fi
Sun Dec 4 05:14:31 PST 2005
Slight clean-up.
- Martin
Index: pj_transform.c
RCS file: /cvs/maptools/cvsroot/proj/src/pj_transform.c,v
retrieving revision 1.14
diff -u -p -r1.14 pj_transform.c
--- pj_transform.c	5 Nov 2004 06:05:11 -0000	1.14
+++ pj_transform.c	4 Dec 2005 13:07:47 -0000
@@ -465,9 +465,9 @@ int pj_geocentric_to_wgs84( PJ *defn,
             if( x[io] == HUGE_VAL )
                 continue;
-            x[io] = x[io] + defn->datum_params[0];
-            y[io] = y[io] + defn->datum_params[1];
-            z[io] = z[io] + defn->datum_params[2];
+            x[io] = x[io] + Dx_BF;
+            y[io] = y[io] + Dy_BF;
+            z[io] = z[io] + Dz_BF;
     else if( defn->datum_type == PJD_7PARAM )
@@ -515,9 +515,9 @@ int pj_geocentric_from_wgs84( PJ *defn,
                 continue;
-            x[io] = x[io] - defn->datum_params[0];
-            y[io] = y[io] - defn->datum_params[1];
-            z[io] = z[io] - defn->datum_params[2];
+            x[io] = x[io] - Dx_BF;
+            y[io] = y[io] - Dy_BF;
+            z[io] = z[io] - Dz_BF;
@@ -593,13 +593,13 @@ int pj_datum_transform( PJ *srcdefn, PJ
         CHECK_RETURN;
         src_a = SRS_WGS84_SEMIMAJOR;
-        src_es = 0.006694379990;
+        src_es = SRS_WGS84_ESQUARED;
     if( dstdefn->datum_type == PJD_GRIDSHIFT )
         dst_a = SRS_WGS84_SEMIMAJOR;
-        dst_es = 0.006694379990;
+        dst_es = SRS_WGS84_ESQUARED;
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20051204/16c245a1/attachment.sig>
