[Proj] WGS84 definition
Clifford J Mugnier
cjmce at lsu.edu
Mon Dec 5 11:57:27 PST 2005
Dear Martin,
I think such lofty declarations are a bit out of the ballpark for PROJ4
users. PROJ4 does not claim to be the torchbearer for the "total answer to
Computational Geodesy." Which reference frame is used should be restricted
to the user's conscious choice (if any), of their data and the concomitant
metadata associated with that choice.
My guess is that most PROJ4 users couldn't care less about reference frames
and the (very) basic foundations of coordinate systems and reference
frames. For those that DO care, they should be capable of recognizing the
differences between map projection implementations and the necessary datum
shift algorithms and associated shift parameters. PROJ4 is not intended
ONLY for Europe, so provincial declarations are more confusing to the
neophyte than helpful.
Merry Christmas,
Clifford J. Mugnier
Chief of Geodesy
CENTER FOR GEOINFORMATICS
Department of Civil Engineering
LOUISIANA STATE UNIVERSITY
CEBA 3223A
Baton Rouge, LA 70803
Voice and Facsimile: (225) 578-8536 [Academic]
Voice and Facsimile: (225) 578-4474 [Research]
http://www.ASPRS.org/resources.GRIDS
http://www.ce.LSU.edu/~mugnier/
Dear List,
I found a nice explanation of the various realizations of WGS84 at the
address
http://www.gps.gov.uk/guide4.asp
I am sorry if this has been asked before, but what is the WGS84 that
proj4 (and GIS software in general) refers to? Of course this only
matters at the better than dm level, so is really only meaningful for
geodesy.
The most sensible thing, I think, would be to refer to a realization
fixed to the local crust. I.e. in Europe, ETRF89. That way the
transformations are not time dependent -- though also not globally
valid.
Does this question have an answer, or a policy, within proj4?
- Martin
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20051205/4150eaa9/attachment.obj>
More information about the Proj
