[Proj] Finnish KKJ in proj 4.4.9
Roger Oberholtzer
roger at opq.se
Tue Dec 13 00:15:55 PST 2005
On Mon, 2005-12-12 at 23:01 +0200, Martin Vermeer wrote:
> On Mon, Dec 12, 2005 at 04:18:57PM +0100, Roger Oberholtzer wrote:
> > I am exploring using proj to obtain KKJ coordinates from WGS84 lat/long
> > values. The values only get to within 176 meters of where they are
> > expected to be (according to the Finnish Road Authority). Is anyone else
> > using proj to obtain Finnish KKJ values?
> > Roger Oberholtzer
> > OPQ Systems AB
> Which are you using? I tried <2393> from the epsg file:
> # KKJ / Finland Uniform Coordinate System
> <2393> +proj=tmerc +lat_0=0 +lon_0=27 +k=1.000000 +x_0=3500000 +y_0=0
> +ellps=intl +towgs84=-90.7,-106.1,-119.2,4.09,0.218,-1.05,1.37 +units=m
> +no_defs <>
I got closest with:
# KKJ / Finland zone 2
<2392> +proj=tmerc +lat_0=0 +lon_0=24 +k=1.000000 +x_0=2500000 +y_0=0
+no_defs <>
That was the one that got me to within 176 meters.
> just last week, and got within decimetres of the right values according
> to the Ollikainen publication.
> The command I used was
> ./cs2cs +proj=latlong +ellps=WGS84 +to +init=epsg:2393
I have been trying via the C API. I gave that string to pj_init_plus(),
which should use those strings.
> The test point I use is triangulation point 158:
> 23d55'11.134"E 63d29'4.016"N 23.847
> 3346722.90 7046208.88
> from Matti Ollikainen (1993): GPS-koordinaattien muuntaminen
> Kartastokoordinaateiksi, pages 29-31 (Finnish Geodetic Institute)
> Are you sure you are using the right zone? There are four of them,
> 2391-2394, three degrees apart.
I tried them all. The one above gets me closest.
I have a Windows program that claims to do the correct transformations:
Program name EurefMuunnos
Author and date Sakari Haljala, NLS 4.9.2003
Copyright National Land Survey of Finland, Helsinki 2003
This is what we are trying to match. These are some sample data points
they provided:
EUREF-FIN- geographic coordinates in format: aamm.mmm = degrees+minutes
(latitude, longitude):
6011.048456 2456.961511
6011.917399 2456.117327
6012.283731 2455.387040
6013.139141 2457.086345
6010.570229 2455.930532
6012.467191 2456.127325
6013.045471 2458.825683
KKJ- plane coordinates in Gauss-Krüger zone no. 2 (northing, easting):
6675107.237 2552856.284
6676709.563 2552052.761
6677380.277 2551368.203
6678990.902 2552915.797
6674205.682 2551915.400
6677730.555 2552047.542
6678840.480 2554525.154
How would I set that up in cs2cs? The input is EUREF-FIN, not WGS84. In
fact, my real data (not these test points) will be WGS84 from a GPS
receiver. But I would like to verify these points as well.
Roger Oberholtzer
OPQ Systems AB
More information about the Proj
