[Proj] Alaska State Plane Coordinates (NAD83) - Hotine Oblique Mercator ??
Oscar van Vlijmen
ovv at hetnet.nl
Fri Dec 16 03:48:26 PST 2005
> From: Anthony Dunk <AnthonyD-rocketmail.com>
> Has anyone successfully implemented support for the Hotine Oblique
> Mercator for the Alaska SPCS Zone 1 (5001) using PROJ4 ?
> Are these parameters correct ??
Don't think so.
One 'official' test point from the GCTP test suite, including the header
information:
Alaska, Zone 1 AK_1 6101 5001
STATE PLANE PROJECTION PARAMETERS:
Zone: 5001
Datum: NAD 27
OBLIQUE MERCATOR (HOTINE) PROJECTION PARAMETERS:
Semi-Major Axis of Ellipsoid: 6378206.400000 meters
Semi-Minor Axis of Ellipsoid: 6356583.800000 meters
Scale Factor at C. Meridian: 0.999900
False Easting: 818585.567227 meters
False Northing: 575219.245107 meters
Azimuth of Central Line: -36.869898
Longitude of Center: -101.514031 degrees
Latitude of Center: 57.000000 degrees
INPUT LONG LAT X Y OUTPUT LON OUTPUT LAT
-135.00 58.50 740839.52660 743026.80896 -135.00000 58.50000
The "Longitude of Center" is not the correct lonc, it is indeed -133d40m
With my version of omerc (derived from Libproj4) and the following
parameters I got:
// first set Clarke 1866, NAD27 ellipsoid
lat = 58.5; lon = -135;
lat0 = 57; lonc = -133d40m;
alfac = -36.869898; gamma = "";
k0 = 0.999900; x0 = 818585.567227; y0 = 575219.245107;
Result: x = 740839.526599844; y = 743026.808961898
The alfac is officially defined as the arcsine of -0.6, so an even better
value of alfac would be -36.869897645844 degrees.
More information about the Proj
