[Proj] GDA94 projection
Frank Warmerdam
fwarmerdam at gmail.com
Mon Jul 18 22:23:58 PDT 2005
On 7/19/05, Hamish <hamish_nospam at yahoo.com> wrote:
> > I was wondering about the ability to reproject into GDA94 (geocentric
> > dataum of australi) using proj4 libraries, and something like gdalwarp
> > from gdal. I know that gda94 is very close to wgs84, but it would be
> > good to be able to use gda94. Ideally I would like to call gdalwarp
> > with proj4 arguments like:
> > -t_srs '+proj=utm +zone=55 +datum=GDA94'
> Searching the EPSG file shows this is code 28355.
> Use +proj=utm +epsg=code
# GDA94 / MGA zone 55
<28355> +proj=utm +zone=55 +south +ellps=GRS80 +towgs84=0,0,0,0,0,0,0
+units=m +no_defs <>
Hamish,
I think that "+init=epsg:28355" would use the predefined coordinate
system. However, I see it's definition is essentially equilvelent to
WGS84 so it doesn't really provide the GDA94 specific definition
that Robert was hoping for.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the Proj
