[Proj] Projection of SHP file nightmare.
Dave Sampson
gis at watersheds.ca
Tue Jul 19 10:59:40 PDT 2005
Problem:
Wanting to display various shape files (and a DEM raster) that use
varying projection or that are un-projected on a X-Y grid. The X-Y grids
I believe I could guess at a few potential projections. The challenge
has been to get them to all show up together.
using GRASS I can get each to display on their own and have followed all
the docs, mailing lists etc for all the sotware that I'm using. Is there
another way?
I know the *.prj files hold projection data. Can you 'trick' the files
by editing those?
Main Projection (of projected and unprojected data)
UTM
NAD83 zone 18 (18T according to topographic series if that makes a
difference)
Primary Software tools
QGIS
UDIG
UDIG
(would like to avoid booting up windows to use ARCVIEW, GFOSS should be
at this stage)
Extra notes:
In reference to my next mailing to the list I get these lines when I run
PROJ from the prompt. Any ideas?
sampson at dryad proj-4.4.9 $ proj
proj: Symbol `pj_list' has different size in shared object, consider
re-linking
proj: Symbol `pj_release' has different size in shared object, consider
re-linking
Rel. 4.4.9, 29 Oct 2004
usage: proj [ -beEfiIlormsStTvVwW [args] ] [ +opts[=arg] ] [ files ]
|Dave Sampson: Geographic Information System (GIS) Technician |
|Centre for Sustainable Watersheds |
|Cooperative Approaches to Protect Canada's Water Resources |
|14 Water St, P.O Box 280. Portland Ontario, Canada. K0G 1V0 |
|Lat: 44.700 Long: -76.19 |
|www.watersheds.ca gis at watersheds.ca |
More information about the Proj
