[Proj] (re)projection of rasters
    Michael P Finn
    mfinn at usgs.gov
    Wed Jul 20 10:03:37 PDT 2005
Dave,
We have a program in the government domain, MapImage (mapimg), which
specializes in reprojection of raster data, primarily for small-scale
applications. You can find it at:
http://carto-research.er.usgs.gov/projection/acc_proj_data.html.
It may work for what you are trying to accomplish. There is a User's Guide
available as well. We are very close to a new release (version 2) with a
few more features. If mapimg looks like it will help you, we will be happy
to give you a pre-release beta version to try.
We hope to publish a full paper soon on the details but, in the meantime,
in addition to the user's guide, you can check out this abstract and
presentation from Auto-Carto 2005:
http://carto-research.er.usgs.gov/projection/pdf/abstractMapimgAutoCarto.pdf
, http://carto-research.er.usgs.gov/projection/ppt/autoCarto_V2.ppt.
Mike Finn
Michael P. Finn
Applications Programming IT Specialist
National Geospatial Technical Operations Center
U. S. Geological Survey
Rolla, MO
(573) 308-3931
mfinn at usgs.gov
Dave Sampson <gis at watersheds.ca>
Sent by: proj-bounces at lists.maptools.org
07/19/2005 04:42 PM
Please respond to
"PROJ.4 and general Projections Discussions"    <proj at lists.maptools.org>
To
cc
Subject
Alright,
last time I was looking at vectors. and ogr2ogr -a_srs WGS84 dest src
worked well for me
Now I would like to take a raster of the bellow characters and bring it
into the same layer format. I have tried various things with
gdal_translate, proj/invproj, but I don't think I actualy understand
what I'm trying to do (aka I give up). Although I have successfully
taken a directory of 8 *.adf files (the DEM I would like to import) and
changed it to a GTIFF. Now if I could reproject it (in the same or
different step) would be nice.
My understanding is that I want to move catesian data (1) to
cartographic data (2)
My location as seen by GRASS
LOCATION PROJ_INFO is:
GRASS_INFO_ERROR(10270,2): name: Lat/Lon
GRASS_INFO_ERROR(10270,2): proj: ll
GRASS_INFO_ERROR(10270,2): datum: wgs84
GRASS_INFO_ERROR(10270,2): a: 6378137
GRASS_INFO_ERROR(10270,2): es: 0.0066943800
GRASS_INFO_ERROR(10270,2): no_defs: defined
Data to bring in seen by GRASS
Dataset PROJ_INFO is:
GRASS_INFO_ERROR(10270,2): name: Universe Transverse Mercator
GRASS_INFO_ERROR(10270,2): proj: utm
GRASS_INFO_ERROR(10270,2): datum: nad83
GRASS_INFO_ERROR(10270,2): zone: 18
(data in Ontario MNR DEM in *.adf format)
I have tried
(inv)proj +ellps=WGS84 src
but think I'm missing something. Seemed like a good idea.
I have also tried (as per docs and tutorials) to create a new location
to import raster to, then turn around and try to reproject the data from
one location to another. I missed something along the way cause that
never seemed to work.
I'm sure there is a simple solution.-
|Dave Sampson: Geographic Information System (GIS) Technician            |
|Centre for Sustainable Watersheds               |
|Cooperative Approaches to Protect Canada's Water Resources              |
|14 Water St, P.O Box 280. Portland Ontario, Canada. K0G 1V0             |
|Lat: 44.700             Long: -76.19                            |
|www.watersheds.ca                               gis at watersheds.ca   |
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20050720/70bb759d/attachment.html>
More information about the Proj
