[Proj] Re: EPSG GEODETIC PARAMETER DATASET - California SP zone 7 (fwd)
Dardo D Kleiner - CONTRACTOR
dkleiner at cmf.nrl.navy.mil
Fri Jul 22 12:15:30 PDT 2005
FYI:
------- Forwarded Message
Dardo,
This has been brought to our attention by another correspondent. Yes the FN
value should be 4160926.74. We have corrected it by deprecating coordinate
operation code 10407 and coordinate reference system code 26747 and
replacing them with new records 10408 and 26799 respectively. These will
appear in the next version of the dataset to be published.
Thank you for bringing this to our attenion.
Roger Lott
for OGP geodesy subcommittee
- ----- Original Message -----
> This messages was generated from the online contact form located at
> http://www.ogp.org.uk/Comms/Comment.asp
> name : Dardo D Kleiner
> title : Contractor
> company : Naval Research Laboratory
> address :
> city : Washington, DC
> country : USA
> email : dkleiner at cmf.nrl.navy.mil
> phone : 202-404-7019
> fax :
> message : epsg_coordoperationparamvalue table correction for record:
> coord_op_code | 10407
> coord_op_method_code | 9802
> parameter_code | 8827
> parameter_value | 416926.74
> param_value_file_ref |
> uom_code | 9003
> Shouldn't parameter_value be 4160926.74?
> joinupdate : no
------- End of Forwarded Message
Dardo D. Kleiner
Connection Machine Facility, Center for Computational Sciences
Naval Research Laboratory (Washington, DC)
dkleiner at cmf.nrl.navy.mil -- 202.404.7019
Dardo D. Kleiner
More information about the Proj
