[Proj] Re: Campo Inchauspe towgs84 parameters?
Markus Neteler neteler at itc.it
Fri Nov 11 06:52:33 PST 2005
Frank Warmerdam wrote:
> Markus,
> Is there really only one EPSG translation to WGS84
> offered?  If so, I am surprised it isn't already in the EPSG
> file.  Perhaps it was added since 6.5 that I last used.
Frank, I also found it in EPSG 6.4 and only found a single
set of (3) parameters as posted.
> Looking at Cliff's column, it seems EPSG shift is quite
> different than the NIMA one Cliff indicates.  This would
> make me quite nervous about picking just one of them as
> authoritative.
Right, hopefully we can find an answer in this forum.
> I would add that "custom overrides" for
> datums are very hard for me to maintain currently.
> I do hope to reprocess the EPSG 6.8 database soon, and
> if the autotranslation picks the -148,136,90 solution then that
> will appear in the file.
There must have been a reason to not having it already since it
is already in the EPSG V6.4 SQL DB. Maybe my query is wrong.
Best regards
 Markus
