[Proj] Re: Campo Inchauspe to WGS84 parameters
Sun Nov 13 21:56:12 PST 2005
On 11/11/05, Noel Zinn <ndzinn at houston.rr.com> wrote:
> Mr. van Vlijmen,
> Excellent!  The 10-parameter Molodenksy-Badekas transformation is the right
> solution for small areas.
> Is it supported by Proj.4?
Noel,
No, I'm afraid not.  Not that I am well read, but this is the
first time I had heard of it.
Cliff's points on the dangers of accepting approximate
datum transformations is also well taken.  I would however
note that most mappers cannot afford to place geodesists on
the ground.   So we scratch around hoping to find something
reasonable.
Best regards,
