[Proj] converting from UK ordinance survey to lat/lon
Andrea Edwards andrea.edwards at nulc.ac.uk
Tue Nov 15 02:24:51 PST 2005
Hi
I am trying to use proj4 to convert from uk ordinance survey coordinates to latitude and longitude values.
I found an example in the internet as so
C:\> proj.exe -I +init=world:bng +ellps=WGS84
353600 432900                        (input)
2d42'15.556"W   53d47'22.952"N       (output)
This does not work for me. I get this error
projection initialization failure
cause: no system list, errno: 2
program abnormally terminated
I think this is something to do with the world:bng file (don't know what that is though). I copied this file to the same directory as proj4 in case that helped but it didn't.
Thanks in advance for your help
andrea
