[Proj] converting from UK ordinance survey to lat/lon
José Alberto Gonçalves jagoncal at fc.up.pt
Tue Nov 15 03:32:41 PST 2005
Sorry for the **. It should be:
   proj.exe -I +init=./world:bng +ellps=WGS84
Jose' A. Gonçalves
José Alberto Gonçalves wrote:
> Try this syntax:
>   *proj.exe -I +init=./world:bng +ellps=WGS84*
> It just tells that file "world" is in the current directory.
> Jose' A. Gonçalves
> Andrea Edwards wrote:
>> Hi
>> I am trying to use proj4 to convert from uk ordinance survey
>> coordinates to latitude and longitude values.
>> I found an example in the internet as so
>> C:\> proj.exe -I +init=world:bng +ellps=WGS84
>> 353600 432900                        (input)
>> 2d42'15.556"W   53d47'22.952"N       (output)
>> This does not work for me. I get this error
>> projection initialization failure
>> cause: no system list, errno: 2
>> program abnormally terminated
>> I think this is something to do with the world:bng file (don't know
>> what that is though). I copied this file to the same directory as
>> proj4 in case that helped but it didn't.
>> Thanks in advance for your help
>> andrea
>> Proj mailing list
>> Proj at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/proj
> Proj mailing list
