[Proj] UTM Zone projection parameters to pass to pj_transform()
Ed McNierney ed at topozone.com
Mon Nov 28 13:04:01 PST 2005
David -
You should expect that.  A rectangle in UTM coordinate space is NOT a
rectangle in lat/lon space.  Make sure you take that into account when
you use the reprojected data coordinates.
	- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
[mailto:proj-bounces at lists.maptools.org] On Behalf Of Jacques, David -
Fort Worth, TX
Sent: Monday, November 28, 2005 3:53 PM
To: proj at lists.maptools.org
Subject: [Proj] UTM Zone projection parameters to pass to pj_transform()
Eric...
That did the trick.
Though I am puzzled that the output doesn't have staight edges.
-94.441707,29.627886
-94.440730,29.559136
-94.371949,29.628626
-94.371019,29.559874
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
